flat pattern of complex surface
Can Pro/E (more specifically version 2001) do a flat pattern of a sheetmetal part that has a complex surface in it?
I have a somewhat spherical emboss in a sheetmetal part, and when I do a flat pattern, it flattens everything but this complex emboss.
Any workarounds?
Any workarounds?
RE: flat pattern of complex surface
It is located under Insert-->Shape-->Flatten Form (It is also on the sheetmetal toolbar, on the flyout with the form feature, right next to the form feature). Start the tool, select Form-->Define, and pick the rounded surface on the emboss, and then press done a few times (eek! 2001 menus coming back to haunt me in WF2!).
Hope this is what you were looking for.
Mark
There are programs that can do this. Most stamping toolmakers have such programs. Look into Superform and its kin.
Derek
thanks again.
