BREAK OUT SECTION
BREAK OUT SECTION
I am a new user to UG, and I am currently using nx 1.0.4.2 can somebody explain to me step by step, how to make a break out section on a view that was created isometricly
RE: BREAK OUT SECTION
· Click Expand
· Go to WCS -> Orient and take Csys of objects (box inferred)
· Click af model so that xy axis will be in correct position , for cutting 3d iso view
· Make with curve a rectangle in XY face ( this will be the cut out area)
· Click Right mous expand off (back in drawing selection)
· Take break out function at toolbar
· Select view
· Indicate base point (on a cylinder , click face make sure that it will the right vector direction “indicate extrusion vector)
· Then select the four sides of the rectangle curve make sure you go each four
· The choose apply
· And Yes a great victory it is ( It is cut out , I hope
