Design of hydraullic cylinder for crane
We are fabricating a hydraulic cylinder for crane containing oil at pressure of 3500 psi at max. operating temperature of 90 deg. Celcius.
Maximum operating lifting capacity of crane is 5 tons and design lifting cacity of 7.5 tons. Material for hydraulic cylinder is AISI 4140.
Please guide me on which design code is reffered for designing of above cylinder i.e. ASME Sec VIII division 1 or 2, or any other code.
RE: Design of hydraullic cylinder for crane
I would think the simplest and best approach to the problem would be to call a manufacturer of hydraulic cylinders and find out what is available. I can't imagine that it's very worthwhile to design and build your own hydraulic cylinders from scratch.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
