Any way to save layer format?
I am in the middle of a complex drawing and have a need to frequently visit the same "view" as far as what layers are turned on and off.
My drawing has about 80 layers and about 50 of them are almost never needed to be turned on while I am drawing.
Is there a way to flip flop between what layers are on and off without having to go into the layer menu?
I need a way to hit one button and have the same 28 or 29 layers turned on and the rest turned off and frozen.
There has to be a way to do this yes?
Thanks!
RE: Any way to save layer format?
(DEFUN C:Layers1 (/ ) ; Swap Layers
(COMMAND "LAYER" "TH" "*" "FR" "Layer1,Layer2,Layer3" "")
(PRINC))
Use the * to represent wild cards if possible, like Layer* for all layers whose name begins with "Layer".
I think he has R14. Search for the "Bonus Tools" in the www. Install the tools, and You will have a lot of new tools.
Or try IFRs suggestion with the layerr manager...
Lothar
ADT 2004
ACAD 2002
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Yes.. I am using autocad R14.
I'm searching the net for those bonus tools....
Any suggestions on where to get them?
Thanks everyone!! You have no idea how much I appreciate your suggestions.
