static pressure
static pressure
hi
for the wall mountable exhaust fan how will we find the static pressure?
RE: static pressure
RE: static pressure
Use a reliable and trustworthy fan manufacturer and that will tell you what airflow you are getting.
BUT, if you want to have some idea of airflow, use a hood.
The hood however will interfere with the readings and give you a lower airflow than it really is capable of
Friar Tuck of Sherwood
RE: static pressure
See h
If you want to calculate it, you will need to evaluate the path the replacement air takes getting into the room. Then make a curve of dp verses air flow into the room. Overlay the fan curve and where the two lines intersect will be the calculated static pressure in the room.
