Which valve is best to throttle H2O2 at 4-500 psi?
Hello everyone,
What is the best way to manually control h202 under a pressure of 500 psi? This means "hand throttling" for example, using a motorcycle throttle (spring loaded) to control the flow of H2O2 through a valve? Does anyone know of a valve that could be used in this manner? Is there an off-the-shelf valve that can do this? The throttle valve should be lightweight and H2O2 compatible. Other characteristics should be: at 35% of initial stroke thrust requirement = 75%. Positive shotoff at the end of the of the stroke and low breakout and running friction to allow smooth throttling action. Anu suggestions or comments would be greatly appreciated. Thanks.
RE: Which valve is best to throttle H2O2 at 4-500 psi?
The valve must be H2O2 compatiable, seal and rings and all. Positive shutoff at the end of the stroke, low breakout and running friction to allow smooth throttling action. The valve should be of a plunger, spool and body type.
Any ideas... I would appreciate them greatly. Thanks.
m777182
