Mixing refrigerants
Mixing refrigerants
What determines an azeotrope from a blend when two refrigerents are mixed
RE: Mixing refrigerants
pennpoint
Additionally, the volumetric composition and saturation temperature of zeotropic blends change when used in refrigeration systems, wheras the azeotropic blends do not. In other words, the components of a zeotropic blend (say R401A which contains R-22, R-152a and R-124) have different vapor pressures and boiling points; so when the fluid evaporates or condenses, the liquid and vapor components will have different compositions.
More detailed info in a highly readable form is available at
www.qwik.com/R410A/R410A_manual.html
