Thread Design Question
I am designing a 6" female thread dia. screw in flange for a marine electronics housing (surface application, low pressure). I am looking for the best thread design (standard) for ease of assembly (~3 turns to attach), and durability. The female mating flange will be metal (Ti), and the male screw in flange will be delrin. I will be using o-rings for sealing, but would like some taper on the threads to prevent back-out. I am inclined to look at API thread standards; any help will be greatly appreciated. Thanks
RE: Thread Design Question
If you can arrange for at least one axial element in the female threaded part, e.g. a spline or even a single tooth of a spline, you can mold a flared, elastic mating spline or a number of cantilevered arms with spline teeth in the Delrin part. Make the splines asymmetrical, like a buttress thread, and it will be practically inseparable.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
