How to group objects?
I've gotten good at making 3 dimensional drawings but am having difficulty when dealing with overlapping parts.
How do I group a bunch of lines and circles into one object that will move as a group? And then be able to "un-group" them when needed?
Im using AutoCad R14.
RE: How to group objects?
Group is better but I don't remember if R14 supports Grouping. It is also possible to use LISP to create your own collections of objects that you can refer to by name.
I use blocks, not groups. I have a lisp, that makes a anomymous block of the selected objects. Maybe it works in AC14. Intrest? E-Mail?
Lothar
ADT 2004
ACAD 2002
The only problem is that I have never used a lisp routine before. I know what they are but have never required one.
I have much to learn with autocad. I think you would be surprised at how much I have done with this program and how little knowledge of its full usefullness I actually have.
Here is one for 2004:
http://
Lothar
ADT 2004
ACAD 2002
Hope this helps,
John
I tried the UNION command and it keeps telling me that "only coplaner or solids" can be selected.
I can never get the block command to work right.
There's something about drawing in 3D that autocad does not like. It does it, but things quickly become difficult to manipulate because the software wont let me do to much to an object unless I am in the same drawing plane as the object was drawn in.
Keep the suggestions coming!!! Thanks for the info!!!
To get an idea of how different, use the BOX command and the CYLINDER command. You can do Boolean operations on the resulting objects.
You can also make a 3d object by using the EXTRUDE command on a closed polyline.
You _really_ need to find a copy of "Inside AutoCAD". It will take you farther in a week than you've gone so far. Don't bother with the diskette; do all the examples and make your own.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Im going to look around for Inside Autocad.
I wish this forum would let me respond to replies in a stepped order instead of this list type display.
Ok.. Time to get back to my drawing .. LOL
Thanks again!
Murph
tools -> object group
give name (if needed)
[new] select objects
[ok]
this will create a group of objects that will move together
only if groups are turned on
tools -> drawing aids -> groups checked = groups on
un-checked = groups off
you can turn off grouping, then move individual objects, then turn grouping back on and move all objects together.
hope this helps
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
OZZY ,
THANKS !!!!!!!!!!!!!!!!!!!!!!!!!!
