EGT measurement for 150 HP turbo-diesel
Will be grateful if someone suggests a reasonably-priced supplier for a turn-key solution for the above, to include:
1.  Thermocouple sensor for installation in exhaust manifold, upstream of the turbine flange;
2.   A 2' to 2 1/2 " analogue dial gauge for  display on driver´s dash;
3. Wiring between sensor and dial gauge, to be between 6-12 ft (it is for a twin-engined boat application)
4. Boat´s electrical system is 12 V DC (nominal)
RE: EGT measurement for 150 HP turbo-diesel
ISSPRO, Autometer, VDO, Stewart Warner
Thank you optimum .
I accessed Isspro´s page and then some of their nation-wide (US) dealers. The latter provided all the nitty gritty I was looking for.
Reasonably priced turn-key solutions and good looking gauges.
No buying a thermocouple here and a gauge there, thank you!
Happy to help
Tim
I suggest you bolt it on before turbocharger. Only that'll give useful information on what's going on with the EGT's.
Re: "I suggest you bolt it on before turbocharger. Only that'll give useful information on what's going on with the EGT's."
Why is that?
The bigger Diesels have them after the turbo.
