2005 SP1.0 Feb 11th?
I heard a rumor that the next SP would be out by Feb 11th, which is today. However it is not available for download. Does anyone know when the offical release will be? Or do the solidworks programmers only know?
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
RE: 2005 SP1.0 Feb 11th?
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Best Regards,
Jon
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Did you get a reason why the delay in this SP release?
Best Regards,
Jon
Be patient ... better for it be late & working, than on time & cause more problems than it fixes. That's easy for me to say ... I'm still running SW04/SP2.1
The worse is that, one of these days, management will ask me why I'm still running on SW2004, why I have payed for something that it's unusable.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
Now I am curious about what Scott meant by 1.1?
Solidworks are more than eager to call and email months in advance for their fees, but when it comes to putting up the goods they have fallen way short of the mark recently. My renewal is not due until the end of March and I have been receiving calls and emails now to make my payment for 6 weeks. I think that the right thing for them to do would be to start refunding the fees for this year because we still haven’t got what we paid for yet.
I design injection molded and die cast products along with associative tooling and recently I have been wrapping $ bills around the work that I hand over to my customers. I use a large portion of the functionality available in Solidworks and I could create everything that I design now in the 2003 software with none of the delays. I am spending around 20% additional time on my projects in 2005 due to system crashes, lock-ups and rebuild errors.
The bottom line is that Solidworks is slower than ever before and if Solidworks are serious about keeping their number one slot then they need to get the software performing the way that it should.
John Cole
Sr Mechanical Engineer
I know this doesn't address your support concerns, but hope that this suggestion may help you till M$ & SW get the problems fixed. (If ever).
For the record, I agree that SW should either slow down with the releases and/or have even more "real world" testing, to discover & fix the "bugs", prior to releasing any new version. Then they would not need so many patches.
May need double-checking because I am on EV, but it is noted on the main page now.
In Solidworks, went to "Help" > "Service Packs" > "Check" and it found it.
Flores
Thanks!
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
I was holding off on installing (four seats) until SP1+. Now I have one week left here before I start my new job. My new job entails no SW admin responsibilities :)
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Do you mean, in a new company? Good Luck in your new tasks!
To all
It is known that the reason for the delay with this SP (so they say) was an issue with the M$ installer. Now that SP1.1 is released, I was expecting a reference to an M$ patch, but didn't found any. Can I directly install SP1.1 or am I missing something?
Mark Reader
Incisive Surgical
2) You have to pick the language in which to DL. Be sure you picked the appropriate language.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Ex: Bienvenido a la Guía del usuario en línea de SolidWorks. Esta ayuda contiene descripciones e instrucciones para todas las operaciones y funciones del software SolidWorks
Nobody else has had this occur?
Mark
Chris
ctopher's home site
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
thanks Scott.
Chris
ctopher's home site
Similiar to this:
C:\Program Files\Solidworks
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
ctopher's home site
Jeff Mowry
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
ctopher's home site
Did someone else have the same problem?
Best Regards,
Jon
Mark Reader
Incisive Surgical
So just redownload the SW help file and install it.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Best Regards,
Jon
Mark
I would really like to have my help file back.
Best Regards,
Jon
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Solidworks needs to know about this and fix it immediately. Mistakes like those should not be tolerated.
Best Regards,
Jon
I didn't want to mention this, but since you can't seem to read my last few posts, I will tell you - I called SW and asked them about it... and they said they have it fixed and you need to simply "Redownload" the SW help file and install it.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Best Regards,
Jon
That is the only file that is in spanish if I open it directly from the zip file that is downloaded.
Best Regards,
Jon
Mark
The problem maybe the fact you need to remove all your SW help files and reinstall them with the new DL.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Mark
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
