Icon to open an Excel file
All,
I have an Excel document that I would like to have opened in solidworks thru an icon. I would like the icon to be in one of my toolbars. From what I have read you can associate macros to icons, but I do not see how/if you can do that with a strait document. I am not well versed on recording macros either.
THank You
Brad
THank You
Brad
RE: Icon to open an Excel file
YOU ARE GOING TO NEED TO USE THE SECOND CALL TO OPEN A SPECIFIC FILE
Option Explicit
Dim MyAppID
Dim ProgStart As String
Sub main()
' Program starts as normal window with focus (the parameter 1).
' If the program is not in the PATH you have to enter the complete path to the exe.
' Returns an handle for that instance
ProgStart = "calc.exe"
MyAppID = Shell(ProgStart, 1)
' you may also provide parameters (like the file to be opened).
' ATTENTION: if there are spaces in the parameters you have to enclose them in '
'ProgStart = "notepad.exe 'D:\daten\solidworks macro.swb'"
'MyAppID = Shell(ProgStart, 1)
AppActivate MyAppID
End Sub
Good Luck
Remember...
"If you don't use your head,
your going to have to use your feet."
This was found, and used with 2001+ on an NT machine.
Have not used for a while but will get my original macro up on 2005 (WinXP Pro) and see if it functions.
Remember...
