Downward Compatibility from CATIA V5R12 to R11
I am having problems using the Downward Compatability tool. I have both CATIA V5R12 and R11 installed on the same machine (no service packes installed). I need to convert a CATPart from R12 to R11 so others can use the file.  I thought I sucessfully converted the CATPart. This was the report i received:
Current Version : "CATIAV5R12"
Targeted Version : "CATIAV5R11"
OutputDirectory : "C:\Documents and Settings\E5005264\My Documents\My eBooks\"
Conversion of "C:\Documents and Settings\E5005264\My Documents\conversiontest.CATPart"
   Minimal Version to open the document : "CATIAV5R12"
   Document need to be converted
   PartBody was converted (as result with link)
Document successfully processed
However when i open CATIA V5 R11 and try to open the file all i get are error messages in a pop up window i.e.
'C:\Documents and Settings\E5005264\My Documents\conversiontest.CATPart'
Open failed due to invalid or inconsistent extension type
Anyone shed any light?
Marcus
RE: Downward Compatibility from CATIA V5R12 to R11
I've seen this error in R12 but was fixed in SP7.  No guarantees but you can try a later SP of R11.
You can also try running the CATDUAV5 utility in R11 to see if it can "clean" the file.
There's some info on IBM's Tech. Support website on this error message.  Here's some replies from DS:
Problem conclusion
THIS PROBLEM IS PERMANENT RESTRICTION IN
CATIA.
Restriction Explanation
This CATProduct is completly corrupted. A lot of
streams are missing. We can not repair this
document by hand.
No investigation is possible without reproducible
scenario.
Problem conclusion
THIS PROBLEM WILL BE FIXED ON CATIA VERSION
5 RELEASE 15 GA level.
NOTE THAT THIS PROBLEM WILL ALSO BE FIXED
ON V5R14SP04.
Incident Diagnosis
The CATDrawing file cannot be opened.
The message 'Open failed due to invalid or
inconsistent extension type' is given
Correction Explanation
The document is corrupted.
However we can dynamically repaire the document
Answer and By-Pass
The CATDrawing file named :
12738333-Repaired.CATDrawing has been sent to
you. You can open it on V5R12 SP9 or other CATIA
levels (V5R13, V5R14 and so on).
