Step motor leads
Step motor leads
I have a 24 V DC 0.18 A Step-Syn Step motor(Sanyo Denki) out of an old IBM computer. I would like to use this step motor to drive a lead screw in a drilling machine I am designing. There are 5 leads coming out of the Step motor: Black, Red, Orange, Blue, and Yellow. Just guessing I believe the black and red would drive the motor and the other three are from an internal encoder. Am I on the right track and can I find this to be true by testing it with a VOM? If this is the case I plan on connecting the motor directly to a Mitsubishi FXo PLC. The FXo can handle 0.2 A average/ contact, will this be able to poperly power the motor? If so I plan on using ladder logic in a pulse fuction to drive the motor the number of steps necessary. The PLC I am planning on using does not have enough I/O to return the encoder data, can I count on the accuracy of the motor without the feed back of the encoder? I am also looking for suggestions on how to connect the motor to the PLC.
Thanks for your time
Best Regards
Best Regards
RE: Step motor leads
Thanks for your help.
