timber weatherboard clad frame
Hi Fellow
Quick question. For the timber weatherboard clad frame, with timber strip for the internal wall. Is it the carcks in the timber strip is most likely cause by weathering then ground movement? Because in my thinking, any movement from the foundation will cause the timber strip split in the joint location. Is it right? Where can find some provement.
Thank you for your help
Marco
Marco
RE: timber weatherboard clad frame
John
The main thing I concern here is that, will any foundation movement cause the timber strip crack? they are horizontal hand cut strip.
