Excel Data creating a Pro/Engineer (Wildfire) curve
  Does anyone know how to create a datum curve within Pro/Engineer Wildfire from Excel X,Y & Z data points?
RE: Excel Data creating a Pro/Engineer (Wildfire) curve
There are a few ways.
If you want a one shot deal, look at Thread554-109370. Output the files in excel as space delimited text.
Otherwise, you can use an Excel analysis feature, part of the Behavioral Modeling extension. It allows you to link certain dimensions or parameters to cells in an excel file. You can find it under the Analysis menu. This is best if you want the curve to be driven by an excel file.
Mark
