Water flow through a flat screen
Hi, I'm hoping someone can help me:
Are there any formulas for calculating the rate of flow of water through a screen for a given mesh size and pressure?
The proposed application is a gravity-fed inclined flat screen for cooling water, and I need to find out if I can get enough water through in the space I have available.
Jeremy
RE: Water flow through a flat screen
