Atmospheric Tank Venting
I am trying to figure out how to size an open-air vent for a 33,000 gal, vertical atmoshperic tank. There is a known liquid flow in and out of the tank (not always equal), as well as a known air flow into the tank. I keep thinking that one way to do this is to know (which I don't) what velocity the air should be as it leaves through the vent, then figure the balnce, therefore the proper size, volumetrically. But, I can not find a value given anywhere. The API standards to not give such information. I appreciate any and all help.
PS. The liquid involved with the tank is not flammable, so there is no need for emergency venting.
RE: Atmospheric Tank Venting
I think the first consideration is the nature of the product contained by the tank. If it is flammable you want to look at NFPA Standard 30. If flammable product is involved, you want to have both a conservation vent and an emergency vent. The manufacturers of these venting systems (e.g., Protecoseal) will provide free software to allow you to properly size the vents.
Regards, John.
If the liquid is valuable, you may need to consider a vapour recovery system to minimise losses to atmosphere.
If the liquid is high purity you will need a vent filter to ensure cleanliness.
Another factor to watch is the vessel wall strength. If it is unusually weak, you may halve the air flow velocity, to reduce potential pressure rise.
Protectorseal offer some very good advice in their catalogues, and also offer proprietry softwear for the calculations.
The air volume flow is then equal to this value.
Aim for a low linear velocity of air in the vent as mentioned above (perhaps even less that 1 m/s maybe .1 m/s). I dont think emergency venting will be reguried even for a fire case if you have a 4-6" vent line due to the large size on the "hole" (a T type API relief valve have a orifice diameter of 26 sqin (as far as i remember) and a 6" vent line would have a cross sectional area of 28 sqin.
If you really want to do it fancy then use normal dP equations to calculate pressure drop in the vent line and compare with the vessel design pressure.
Best Regards
Morten Andersen
This is just an easy method based on velocity
Best Regrads
Morten
If you can find a copy of Crane's technical paper 410C, Flow of fluids through piping, fittings and valves, it will walk you through the calcs (or find a nearby process engineer, they can run it).
If you can give me an idea of what the vent line is composed of (ie, 6 feet of pipe and 2, 90 degree elbows) and the design pressure of the tank, I can run them for you.
Best Regards
Morten
