Atmospheric Tank Venting
I am trying to figure out how to size an open-air vent for a 33,000 gal, vertical atmoshperic tank. There is a known liquid flow in and out of the tank (not always equal), as well as a known air flow into the tank. I keep thinking that one way to do this is to know (which I don't) what velocity the air should be as it leaves through the vent, then figure the balnce, therefore the proper size, volumetrically. But, I can not find a value given anywhere. The API standards to not give such information. I appreciate any and all help.
PS. The liquid involved with the tank is not flammable, so there is no need for emergency venting.
RE: Atmospheric Tank Venting
I would use two methods when sizing vents for tanks. One method was a down and dirty method of sizing the vent so the SCFM was equal to the largest inlet or outlet. That way, you would always have the venting needed. This would only work on non-flammable and other low vapor pressure contents. This was not my preferred method, but it did work.
The other way I would size vents was to use API-2000. It is a standard written by API to size vents for atmospheric and other API tanks.
You can get it from Global Engineering for $83 at this website: http://www.global.ihs.com and do a search for "tank venting".
