Solidworks 2005 flat pattern rotation.
I am having a problem creating a drawing from a sheet metal part. When I insert the flat pattern into a drawing the flat pattern is rotated 90 degrees. The sheet metal part was created with the fixed feature on the top view if that matters. Any ideas?
RE: Solidworks 2005 flat pattern rotation.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RMB the Flat pattern symbol in the Feature Manager, select Edit feature, select a face, then click on green tick. The drawing view will re-orient itself per the new fixed face. You may have to do this several times until you get the desired orientation ... unless you can fathom out the logic.
An easier way is to rotate the view on the drawing.
RMB on view Zoom/Pan/Rotate/ > Rotate type in angle angle Apply > Close
