Sheet metal template
I am trying to set up a sheet metal template based on observed results from the shop. The values I have are inside radius and bend deducts per material and thickness.
Is there an easy formula to transfer this into Inventor or would I have to play around to get it? Luckily the bends are typically 90 degrees.
