Gravity feed fuel supply
What is the min. pipe size and decline needed to get the fuel from a above ground tank to boiler 100 ft" away on a two line fuel supply system with 4 boilers?
This system has been in use for aprox. 15 years. and now with a new water heater replacment the third boiler whitch is the smalest is fuel starved.
RE: Gravity feed fuel supply
John
