Do you use FlexLM?
Do you use FlexLM?
We currently use a program called Sassafras to manage our seats of SW. Assuming the FlexLM works for most, I am looking for people that have had problems with it and what they were. We are thinking about changing but do not want to change to a system plagued by problems
Thanks in advance
Thanks in advance
RE: Do you use FlexLM?
As for VAR sending you license files etc... You can now do this at the SW website with few problems. If you don't stay up to date with the lastest SW then you will have call into your VAR and they will ave to call SW to get a special Flex license file for your Facility.
SW posts a guide at their site, which goes into the nity grity of the FlexLM file and how do certain things with it. If you looking to customize it, check out the FlexLM guide.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Thanks for the help!
The only problem we have ever had was one time the exclude list that keeps our two groups seperate seemed to quit working, but I think it was a problem with how IS had the groups set up.
The only other problem encountered was users not shutting their session down before going home. That's when we found the time out setting. Now it's no longer a problem.
