Need tool steel identification.
I've got a quantity of tool steel marked `U S Ultra' and can't find it listed anywhere, can anyone help me with the specifications and recomended uses ?.
RE: Need tool steel identification.
I don't find this listed either.  If you could get access to the reference book "Woldman's Engineering Alloys" it might be listed.
There is a current industry project in Japan "Ultra Steels"
Nothing in Woldman's.  There is an entire line of tool steels called Ultra, about a dozen different grades.
Get an analysis and harden a sample.  See what it is.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
I found it in Woldmans. It is basically a type H-11 tool steel, and is registered under U.N. Alloy Steel Corp. They are in Revere, MA 02151. Hope this helps.
Thanks for that Metaldoctor and thanks to you all for taking the trouble to answer ............
