PLC & VB6
PLC & VB6
I am looking for a source of PLC(programmable logic controller) that programs with VB6. I am hoping someone here uses them or knows where I can get info regarding PLC's that can "talk" to each other over a dial-up phone connection.
I need to monitor & control systems over phone lines at remote locations. I think Z-World makes this type of equipment but it uses "C" and I do not know that language.
any info would be helpful.
RE: PLC & VB6
Most PLCs can give you the ability to read/write memory allowing remote control.
The controller you refer to in Z-world is an embedded controller.
Can you describe your application a little bit more?
RE: PLC & VB6
Check out
http://www.tri.com.sg/index.htm
The T100MD PLC is VB programmable.
