Submersible Pumps and NEC
Can anyone tell me where in the NEC book where GFCI would be required on a submersible pump. I read Article 680.51 but that refers to pumps for fountains or near pools. I installed a >1 hp sump pump in a steam pit (190 F inside)) and it seems it would be prone to tripping and cause more harm than good. We removed the cord and hard-wired it inside a sealed junction box to avoid moisture getting in between the plug and receptacle. Wouldn't Article 430 apply in this case? Just supply a local disconnect and no GFI? Elevator pits do not require GFI if fed from a dedicated receptacle. If receptacle and plug was eliminated, less chance of accidental shock. What do you think?
RE: Submersible Pumps and NEC
"Venditori de oleum-vipera non vigere excordis populi"
