PATRAn Group Command
Is there a way to place all of the facets from a single mesh into a group without using a bounding box to capture the individual facets? I have a complex model with multiple meshes and would like to place each separate mesh into its own group in the least painful way.
RE: PATRAn Group Command
But, as far as I know, it is a "special" package of PATRAN (obviously, not free)
You can do it with Utilities. Once you have installed the Utilities section (which is free, as GJS explained) please do the following steps:
1) List 2)Get Solid Elm Faces 3) Put a small tolerance and select close to geometry option 4) Select Surfaces or Solid Faces of your geometrical model (whatever you have as geometry) 5) It selects all of the Solid Elm Faces. I am agree with GJS, most of the features of Utilities are useful.
AAY
http://www.geocities.com/fea_tek/
