Designing pit / trench concrete thickness
This, I'm sure, is basic stuff but I don't deal with a lot of concrete work so I could use a little help. I've got to put some pits into the ground in a processing plant. The pits are roughly 4'x10' x 4' deep and have vertical walls. We will be having these poured. Is there a design reference that I can use to determine how thick the walls of the pit should be, re-bar centers, re-bar size, etc...? Any help or nudge in the right direction would be appreciated.
RE: Designing pit / trench concrete thickness
However, if you do need cast-in-place concrete for pits, such as pump sumps, here are a couple of things to keep in mind:
1. If there is a high ground water table, use enough concrete in the walls and pit bottom to keep the (empty) pit from "floating" out of the ground.
2. Cast-in-place concrete walls less than 6" thick are difficult to construct (space inside the forms is very limited). Eight inch thick walls (minimum) are much more constructable.
www.SlideRuleEra.net
We have poured a few footings before but no in-ground vaults. These are open on top and won't be holding anything other than the occasional worker. I had planned on going w/ 6" walls and #4 rebar 12" O.C., plus pinning the walls to the existing concrete floor w/ #4 rebar 12" O.C. all around the upper perimiter. I think it should be ok, but 'think' is the key word there.
Dick, this is going into a plant with finished epoxy flooring, I am neat saw cutting the floor to have the cleanest end result that won't require any epoxy work.
