dcs vs plc for desalination plant
hi
i am doing the engineering for a desalination plant with a DCS based control system. no of i/os works out to approximately 1400 with a majority of digital signals.  what is best for this application? dcs or plc?
RE: dcs vs plc for desalination plant
The process is continuous and the I/O count is reasonably high.  I gather that most signals will be from transmitters instead of switches.  If so, a DCS should fit well.
John
Today PLCs manufacturers do offer powerfull configuration and Process management tools able to design complete process controls algorithms and sequential logics without requiring complicated DCS systems.
Schneider's new development platform: UNITY do offer the capabilities of a small DCS system at reasonnable costs.
Worth to mention also a new era of ruggedized "open" controllers on industrial redundant Ethernet at even lower costs than PLCs complete with a powerfull development platform such as the MTL Instruments: M.O.S.T. system . and their Workbench tools. In addition, the MOST controllers do not require local stations nor control rooms nor costly protective buildings or installations . Eveything can live outside at temps from - 40°C to + 70°C ambiant...in standard junction boxes..!
HI
Check out this Thread
Yoiu will understand the difference between PLC and DCS
Thread791-74676
Hemant
Instruite
Ideas that works
Concepts that sells
