Hole Wizard errors
Hole Wizard errors
Hole Wizard errors
Hi!
Again troubles with Hole Wizard. This time it shows error messages like this: a)Invalid depth b)Invalid value for hole depth. They appear, when I try to change hole type. After I have changed to all types and start again with first one, it disappears. And with every new hole the same story... Any ideas?
RE: Hole Wizard errors
Did you install SW2005 as a fresh clean install or did you do an upgrade from a previous version?
Also did you turn the Anti-virus program off when installing SW?
& all the best.
Sounds like your DB is corrupted. I would uninstall and completely clean the registry out of all SW. Also remove all SW from the machine including any add-ins you may have (Toolbox, etc...)
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Yes, I installed my SW as a fresh clean install and anti-virus was turned off also. Anyway, I "managed to fix" the problem. What I did was that I clicked "OK" every time, when I changed hole type (error appeared). At that moment, when I had clicked "OK" to last error message - I closed the part. And when I opened it again - surprise - everything was OK and still is. So no SW uninstall this time, but what was the reason I still don't know...
