Thermoset phenolic with reinforced cotton linen
Currently I am needing mechanical properties of a 2-ply laminate thermoset phenolic resin reinforced with cotton linen (long fibers).  The bottom ply is 90 deg, the top ply is 45 deg with respect to the bottom creating a quasi-isotropic material fiber structure pattern.  First, is it suitable to assume the material to be isotropic?  I would like to model the material in Ansys; but the properties are needed for analysis.  In order to get true stress, strain, Young's Modulous, and Poisson's Ratio, would I need to do a dogbone tensile test with strain gages?
I've looked in the www.matweb for info and could not find anything useful.  Where to look?, How to model the material?
RE: Thermoset phenolic with reinforced cotton linen
We had a similar task some years ago and had to go the dog bone test route.
You may  find some relevant maths in a book "Appplication of Fracture Mechanics" by Barsom and Rolfe, published by Prentice Hall.
Good luck
