TIR & Concentricity
TIR & Concentricity
Does anyone know how to measure TIR and Concentricity using a Video CMM.
I am working with a Micro-Vu. I was told that to find concentricity I first find the OD, the ID, and the distance between the two. The distance should then be multiplied by 2. Is this correct? Can this be used to find TIR? Thanks in advance.
RE: TIR & Concentricity
To find TIR you would also add the ovality (or in more precise terms, the maximum deviation of form from circular) of the checked diameter to the distance between centers as a vector sum. I.e. the clocking of the maximum mis-circularity relative to the clocking of the mis-concentricity must be considered.
