Small Hydraulic Pump and Motor
I am looking for a small hydralic pump and motor. The pump drives the motor by some direct oil lines between the two. The pump must around 3" in diameter and 3" long (a cylider, and the smaller the better). The motor may be 4" or 5" in diameter but only 2" long (a cylider as well, again smaller the better). The pump will rotate at low speeds, roughly 60 RPM to 300 RPM. The motor will run around 1RPM to 10RPM. The power being supplied to the pump will be around .5HP at best (probably around .2HP on average) The motor must deliver a high torque output. It is also needed that the pumps will have the drive shafts exiting both sides of the pumps so they maybe driven/drive from either side. Has anyone worked with or heard of pumps/motors these small with such low operating speeds? I have looked at many sites on the net and asked many suppliers and am still lost. Thanks to anyone who can help.
John
John
RE: Small Hydraulic Pump and Motor
The Motor will run from 60RPM to 300RPM as well.
Other than relocating the power, are not you simply connecting themelectric motor to the load?
k
What kind of a load are you going to be moving? That will govern the pump and motor displacement. And, of course, the physical size of the pump and motor.
Have you considered strictly mechanical linkages?
From strictly volumetric considerations the pump motor displacement would be 60:10 or 1 unit for pump and 6 units for motor. Other side of range would be 300:1. I think that you should pick an operating condition so that some figures can be nailed down.
