Concentrated Torque on Wide Flange
I am trying to analyze the situation of applying a concentrated torque to existing wide-flange sections. The torque is applied through a baseplate that is placed atop the top flange, and then a matching plate is placed under the bottom flange. The two plates are then connected using threaded rods (4) and effectively sandwiching the beam. I am positive that I need web stiffeners at this location due to flexure introduced to the web-flange fillet. I just don't know how to go about calculating quantity and sizing. The location of the torque application varies from midspan to immediately adjacent the end supports of the beams. The beams are simply supported by double clip angles.... any thoughts?
RE: Concentrated Torque on Wide Flange
DaveAtkins
