simple vb question
simple vb question
I am writing a bit of code to run with a macro in SW. I have the following:
If txtNumber.Text <> IsNumeric Then
MsgBox ("Use only numbers.")
GoTo waithere
End If
The IsNumeric give an error "The argument is not optional" I have a test box being populated with 5 characters I want to ensure that only numbers are uses else give the error "use only numbers"
Any thoughts on making this work.
Josh
GoTo waithere
End If
Josh
RE: simple vb question
vik
If (Not IsNumeric(txtNumber.Text)) Then
MsgBox ("Use only 5 digit number at end of file name.")
GoTo waithere
End If
CODE
MyCheck = IsNumeric(MyVar) ' Returns False.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Regg
To be honest with you I dont know the purpose. I am about 3 days into programming with VB. I found that code on the www, copied it and tweaked it to look for txt.number.txt.
You're right, but you must be tolerant. Some of us are not programmers (or didn't learn this type of object/event driven language at school). Some hepful macros are done just "by gathering" some lines of code and a lot of trial and error. They may not look nice or reveal a good programming practice, but if they work then they are fine!
"waithere" must be the name of a line in the program. Look for a line that says "waithere:"--the colon denotes that it is the name for a line used for GoTo.
If you want users to limit data entry to 5 digit numbers, you should use the following two functions in VB (or VBA):
1. Set your text box length to 5;
2. Use "IsNumeric()" command.
Alex
