Tubular Thermal Expansion
I'm looking for help determining the raidal thermal expansion of a 4140 tube. It is 6" Outside Diameter with a 1" wall. Going from room temp to 2000F.
What will the dimensional changes in the radius be?
RE: Tubular Thermal Expansion
My first approximation is to use CTE for plain carbon steel.
My curves don't go any higher. The yield strength at 1200F is less than 10ksi.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
I'll give the CTE a shot and see how the numbers work out.
