form new subassembly issue
I'm in the process of documenting a sheet metal cabinet and am forming subassemblies within the main assembly as the manufacturing process dictates.
I just formed a new subassembly and got the following:
In the main assembly, the new subassembly appears fine. If I open the new subassembly in a new window, however, the new subassembly only shows 1 part when there should be several.
If I do File, Find References, all the correct information is there. If I look at the assembly statistics, the information shows only 1 unique part.
Anyone ever seen this and how might I fix it?
Dave Gowans
Dave Gowans
RE: form new subassembly issue
Here's what did it:
After forming the new subassembly, I opened it in a new window. As before, I could only see 1 part. The feature tree looked as I expected, but the assembly itself displayed incorrectly. I then set all the components to lightweight, at which time everything displayed correctly. Upon resolving the components again, everything appears fine!!!!!!
Any thoughts? A new way to CTRL-Q?????
Dave Gowans
Nothing to do with the system config...( have VAR/SW recommended configs all over engg dept)
When I saved the file and closed SW and started another window and opened the file it was fine.
Happened to me several times today.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
