bushing tolerance
bushing tolerance
I am looking for a shaft and bushing combination. THe shaft will have a medium load, low rpm, at normal temp, and occasional use. THe bushing will not be lubricated. I would like to use brass or bronze.
I am curious about the surface roughness specs for the shaft and bearings as well as the dimsional tolerances for the shaft and bearing.
RE: bushing tolerance
http://www.oiles.com/p-design-guide.cfm
