Changing career directions
Just wanted some advice or experiences on what it would take to go from one career path in civil engineering (structures/bridge design) to other areas of civil engineering (site development, buildings, etc.) without having to start totally over.  I have some experience in these other fields but never been involved in the full aspect of the design.  The field I am in right now has been up and down for the past three years and I have been laid off at least once.  I am wanting to branch out and learn other aspects of engineering and be more stable in the market area.  I have been doing  bridge design for about 5 years.  Any advice, comments, suggests or past experiences would be great.
RE: Changing career directions
willijamie:
I think your biggest hurdle will be trying to convince a new/existing employer that you have the necessary education/skills to handle a new line.  If you search long and hard enough, maybe someone will be willing to give you a try.  Don't overlook desperation on their part, especially if it's a less travelled path.
I started out in structural (buildings, not bridges), and after 2 years, I did a stint in environmental (well drilling, water quality), since I had sort of a dual degree.  What I found was that the grass wasn't greener, just different issues on a day to day basis.  After 2 years of that, I came back to structural where I've been for about 26 more years.
I think deciding on a career path, and regular confirmation of your decision, is really a lifelong thing.  Tough decision to ask of someone when they're only 17 - 22 years old, especially since most times you really don't know what you're getting into until you commit and actually do it.
Good luck.
Does your existing job offer you the opportunity to learn or practice whatever else you want to do ?  If yes, grab the opportunity, even if it means some extended hours of work.  Show initiative the other areas, eventhough that may not be part of your routine work.  Over a period of time (you are the best judge to decide how long this should be), you would have acquired both the skills set required (gives you self-confidence) as well as a professional standing (may be required for getting a job).
HVAC68
