Ingersoll-Rand KVG Bearings
Well I will take a stab and start a thread.
We have several integral KVG gas compressors with crank shaft bearings of the following specs:
Main Bearing - 11" ID x 6-1/4" W
Power Con-rod Bearing - 10" ID x 4-7/8" W
Compressor Con-rod Bearing - 10" ID x 8-1/2" W
What bearing manufacturers make bearings for these engines in the USA?
Here are the ones I found, can anyone add to the list?
Odessa Bearings
Miba Bearings - McConnelsville Plant (used to be F-M)
Washington Ironworks
United Bearings
Terrecorp - (Currently not making flanged bearings)
I'm not sure if United makes the bearings or simply markets someone else's product.
I'll post my second question later.
Odessa Bearings
United Bearings
dwedel
Hotrod Big Engines!
RE: Ingersoll-Rand KVG Bearings
