implementing 'simply supported'
simple question from a new user of workbench 9.0:
i have a beam i want to put in compression, with ends free to rotate as the beam curves (buckles) in compression. i think this should be 'simply supported'.
but the 'simply supported' button is grey when 'environment' is highlighted in the outline.
how can i implement the supports i need?
thank you!
thank you!
RE: implementing 'simply supported'
Using given displacments option in Ansys-WB
Logesh.E
is there some way to get around this? or a different type of support to use?
thank you
