Another Hole Note Question
I know there's been a lot of questions regarding hole notes. I am adding another to the list. I'm using 2001.
Is there any way to edit existing hole notes? When I have a not I right click and select properties. In the text box it usually says something along the lines of "Note_#"
Is there a way to find that file call out so I can make a few changes?
Thanks.
RE: Another Hole Note Question
If you do not see the note icon in the model tree then you will first have to go to VIEW > MODEL TREE SETUP > ITEM DISPLAY then make sure notes is checked on the left hand side of the icon box.  Then you should be able to go the model tree click on the note icon and RMB then modify.  The notes dialog box will appear allowing you to edit the notes.
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
Thanks. I am slapping myself for that question. I should have known.
