Variables and data table
I want to start using Mathcad instead of Excel but I am having trouble figuring out how to do something in Mathcad.
Usually in Excel, I have several variables that have a lot of data associated with each one. For instance, I would create a table that looks like this in excel:
SHAPE:             Ag     rx      ry     rz
L3x3x3/16    1.090    0.933    0.933    0.596
L3x3x1/4    1.440    0.926    0.926    0.592
L4x4x1/4    1.930    1.250    1.250    0.795
L4x4x5/16    2.400    1.240    1.240    0.791
Then I would have a pulldown menu that contains the variables: L3x3x3/16  L3x3x1/4  L4x4x1/4  L4x4x5/16.
Then based on the variable I choose, all the other properties are automatically assigned somewhere in the spreadsheet(Ag, rx, ry, rz) from the "index" and "match" functions.
Is there something equivalent to this in Mathcad? I don't want to have to type in all the different properties each time for each variable.
RE: Variables and data table
Okay, I inserted my data as an "input table" which is being read from an outside text file. So I am just getting raw numbers which are in the form of an array which I am able to access each number indiviudally wherever I need to. So that is great.
But I need to assign units to each data value that I am getting from the array, and the units will vary (some numbers represent areas, others weights, etc.) Everytime I try to assign a unit value I get a new converted number that comes out unitless.
For example I am trying to place "in" (inches) in the placeholder behind the data number "3" that I am accessing from the array. I put "in" in the placeholder and the number turns into "36 in/ft".
If units don't convert correctly, it's most likely that you've redefined a built-in unit somewhere in your sheet that's honking up the unit conversion.
TTFN
I think I figured out what to do. When I access a number from the array, I have to multiply the dimension out to the side.
For example, my data table is an array named "A". I am trying to access the number "5" from the array which is in position (1,1).
Then A(1,1)*IN^2=5IN^2
I mulitiplied the expression A(1,1) by IN^2 to get 5IN^2.
Sounds right.
TTFN
