STEEL WATER PIPE
STEEL WATER PIPE
STEEL WATER PIPE
I am trying to find a chart that converts required wall thicknesses for steel water pipe against Bar pressure.
I would appreciate some assistance.
RE: STEEL WATER PIPE
Reduced to the basics, you should use the thin wall pressure vessel equation:
t = (P · r)/σ
where
t = pipe wall thickness
P = pressure
r = pipe outer radius
σ = pipe material strength (yield or equivalent)
There are other factors, such as corrosion loss factor, fracture due to defects, thick wall pipe considerations, etc.  You will need to do a complete engineering analysis to account for all factors.
Cory
