I have a question!!
I have a question!!
Why exactly do lower frequency sounds have a wider dispersion than higher frequency sounds?
RE: I have a question!!
I guess you are talking about the beaming effect of high frequency sounds.
If you look at the classical acoustic performance of a piston in a semi infinite baffle you'll see that the angular dispersion is very heavily dependent on the ratio of the wavelength to the diameter of the piston. At high frequencies the noise tends to radiate in a straight line directly perpendicular to the baffle, with some sidelobes. However, at low frequencies the piston behaves as a point source and the waves radiate in all directions. AT intermediate wavelengths there is more complex behaviour.
The reason the high frequencies form beams is that the superimposed point sources which form the piston each create a smoothly divergent wave pattern, but these interfere constructively ahead of the piston, and destructively out sideways.
Does that help?
Cheers
Greg Locock
In an indoor situation, a speaker generating a low frequency sound of wavelength 2 metres would be about 1/2 wave in a typical room (assume 4 metre wide room. We would not be able to detect the source location because of the long wavelength. It would be termed omnidirectional (good dispersion). However high frequency sound would beam out in a straight line from the tweeter and would be easily blocked by objects. The dispersion is poor relative to the low frequency sound.
In outdoor noise propagation, air absorption is very high at high frequencies (-7 dB/100 metres and higher)depending on the frequency, and only (0.1 dB/100) metres for the lower frequencies. Therefore a low frequency sound wave can travel much greater distances before air attenuation becomes significant, while higher frequency sound is significantly attenuated in a short distance. This can also be intrepreted as better dispersion.
