Probe for Network Analyzer
Hi, I am a recent graduate who has finally gotten into the EE field. My company recently purchased an Agilent 5070B Network Analyzer, which I will be using to test various RFID tags and antennae. I am fairly confident in using the Network Analyzer, as I had some training in school with a similar model. However, having never purchased such things before, I am having trouble finding the best probe set for this application.
The RFID antennae I will be examining are in the 915 MHz range, and the Network Analyzer is a two-port model. If any of you could recommend a company and part number, I would be very grateful.
Thanks!
Thanks!
RE: Probe for Network Analyzer
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
If you need an antenna probe, make it yourself with coaxial cable. quarter wavelength is about 3 inches long.
kch
You didn't mention the purpose for the probes. Calibrated antennas are available from many sources.
Cables which connect the Network Analyzer to the device(s) under test are rendered "Invisible" to the Network Analyzer by calibrating through the cables to a calibrated short, open and load.
I regularly use calibrated cables, but haven't ever used (or seen for that matter) formal probes...then again, I mainly use a network analyzer for broadcast purposes where connections are made with BNC, TNC, N, SMA and SMB and even GR connectors. (Heaven forbid I ever need to use a PL-259)
Please post here when you find probes.
I remain,
The Old Soldering Gunslinger
