Problem Selecting Arc ACAD 2000
Hi All,
I have a drawing in model space and a layout in which I want to add dimensions.
I can select and two points and create a linear dimension. I cannot select any of the arcs in the my drawing. I have checked the properties and they are arcs. I can select the quandrant and centre of the arc for linear dimensions. I can select any of the arcs in model space and create a radial dimension.
I have also noticed that the dimensions do not scale in paperspace, there doesn't seem to be any association.
I have tried changing my selection and snapping options but that doesn't help.
I've never had this propblem before and it seems to be every drawing.
Any ideas?
Any ideas?
RE: Problem Selecting Arc ACAD 2000
I don't think Autodesk really sorted out dimensioning from paperspace (layout tabs) until 2004 with any degree of reliability. I never had 2002 so I can't be certain of that.
www.resourcecad.com ~ for your CAD solutions
We discovered this because we just had our engineering department decide to move from using model space to paper space to give us flexibility in our drawing outputs. We like everything about this move except the but you described. We are hoping management will approve an upgrade soon.
