Curved plate deflection under load
Hi all,
My question relates to design of beam to support a curved plate 364mm long 42mm wide 3mm thich under o loading point 195mm from one end and a load area of 11mmx2mm the load is approx 10kilos> I want to calculate the deflection along the plate and design a beam to suit and hopefully standardise a method of calculating this for different arching heights with the plate. Any info will be greatfully recieved
jwyn
jwyn
RE: Curved plate deflection under load
