PDMWorks 2005 VS Solidworks2004
Does it work properly if I install pdm2005 on sw2004 ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: PDMWorks 2005 VS Solidworks2004
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
Bradley
SWscience, such a setup will work fine. It is fully supported by SolidWorks, and we have been doing that for about a month without any issues. However, are you running stand-alone licenses of SolidWorks and PDMWorks? If you are, there is a bug in the licensing scheme that will prevent the stand-alone client of PDMW from grabbing a license if you upgrade it to 2005 while keeping SW at 2004. (The SW add-in will work fine, though.) If you are on network licenses, you should not have any issues and the PDMW upgrade should go smoothly.
