Automatic Fillet?
Automatic Fillet?
Hi.
I have a web thats draft faced each side in two directions, that eminates from a curved wall. the point where it joins is 4mm, and thins out in two directions outwards and upwards to the center of the bowl to the top face of the part.
The flat face thats left on the top of my web needs a 'full' radius all the way along it.......however Im not having much luck using a variable fillet and multiple points. Theres about 5 points to pick per side that will keep the fillets consistant to each side of the web, but this doesnt accurately create a 'full radius' between each side of my web all along its entirity.
Is there anyway to specify a 'full radius' between such faces automatically, so it calculates and applies the maximum fillet at any given point on its own and applies it?
Sirius2
Sirius2
